wah mods, i did it!!! :)
Started by nero1985, January 09, 2005, 12:51:42 AM
nero1985
u guys i just finish the mods on my wah... i used a 3PDT from of course  DIYSTOMPBOXES and used it for tru bypass and LED switching, yes and LED, its actually right next to the POT under the rocking pedal so when u turn it on u can see a BLUE light under the rocking pedal and it looks like it was a blinking LED cuz when u rock it down it kinda fades out  its just mad cool........ now i kept the buffer in the input of the WAH (not when bypassed) wat i want to know is if i can turn the BUFFER into a little boost... maybe changing the 10K resistor on the buffer's transistor?? any thoughts about it?? ill take pics as soon as i finish it and ill post some samples cuz i actually think my wah sounds just perfect after doing so many MODs to it,,,, help me out u guys.....
jimbob
Great job! I did the same a month ago. Now add a cap selector switch 5p2t from ?radioshack?  to switch between caps- its actually easier to install than it seems. I can help ya figure it out if needed as i enjoy help from others often around here. That, and i can tell you in down to earth terms a 5th grader could understand. :D  Anyway that mod made the best difference! Also try out a few diff caps- so put in some sockets and getr done.
Good luck-have fun
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
Paul Perry (Frostwave)
I can't think of any simple mod that will increase gain without changing the freq response, possibly double the collector resistor on the second transistor??
