How can I remove the EH Polychorus boost
Started by bass_econo, January 12, 2005, 09:37:07 AM
bass_econo
All,
I did a search to try to find some answers and I came up with the obvious resistor fixes etc., but I was wondering if there was a less band-aid approach to correcting the boost of the pedal.
Can anyone help?
James
bass_econo
p1_ind
You could add a volume control to the end of the circuit using a pot mounted on the case to control the volume or a trimmer pot inside to control the volume.
Or you could even add a JFET booster to the end of the circuit with a external volume control or an internal trimmer pot so that you have more control over the volume up or down.
Adam
