In need of a switch for a BOSS pedal...where can I find one?
Started by Kcollins, January 24, 2005, 12:27:41 PM
Kcollins
I'm pretty new to pedal building/modding so I'm not even sure what the switch is called. I've modded about 5 pedals so far and am pretty much addicted. Anyway one of the switches is stuck in the on position so where can i find a replacement?
Satch12879
Physically stuck or electronically stuck?
If physically Steve over at Small Bear Electronics has suitable replacement momentary swithces.
If electronically, you have a bigger, albiet not impassable, problem.
Passive sucks.
Progressive Sound, Ltd.
progressivesoundltd@yahoo.com
Kcollins
well the switch still moves but it stays on so I guess it could be electronically stuck or the switch is just broken inside.
Satch12879
Hmm, ok, yeah, try replacing the switch itself and see if that fixes things.  Steve'll set you up :mrgreen:
Good luck and let us know how it goes!
Passive sucks.
Kcollins
steve is still closed for a while... any other ideas? What happens If it's electronically stuck?
Paul Marossy
QuoteWhat happens If it's electronically stuck?
Then you'll have to identify what is the flip-flop part of the circuit and troubleshoot it - basically two transistors may need to be replaced. I think it's more likely that there is a problem with the switch itself.
Samuel
testable by cutting the wires to the current switch and just touching them to one another - or by shorting across the switch contacts with a screwdriver or something momentarily
Paul Marossy
Quotetestable by cutting the wires to the current switch and just touching them to one another - or by shorting across the switch contacts with a screwdriver or something momentarily
Now I know that, but why didn't I say that?!  :oops:
Oh well, it's a Monday.  :x
Kcollins
Quote from: Samueltestable by cutting the wires to the current switch and just touching them to one another - or by shorting across the switch contacts with a screwdriver or something momentarily
What will this show me?
p.s. This site is extremely helpful!
Paul Marossy
QuoteWhat will this show me?
It will show you that the switch is not functioning properly and that the flip-flop section is functional.
Kcollins
Without removing anything, I tried touching the 2 solder points with a screwdriver and nothing happened. The light automatically goes on and stays on as soon as a cable is put on an imput jack.
Paul Marossy
That could mean that the switch is permanently on the "on" position. Ypu'll need to physically disconnect the switch to do this test properly, though.
Kcollins
Kcollins
Ok; I disconnected the switch completely.  The pedal still goes on as soon as a cable is plugged in. Touching the two wires together does nothing.
bigjonny
Sounds like your flip-flop circuit is busted.
To be sure: test the momentary switch for continuity with a multimeter, so you know if that part works.  If it does: time to learn about flip-flops, or ditch that section, buy a 3PDT, drill your pedal, and make it true bypass.
Kcollins
Quote from: bigjonnySounds like your flip-flop circuit is busted.
I basically have no Idea what any of that means. Someone said that 2 transistors would have to be replaeced? The pedal is a boss ch-1 super chorus, so If anyone would be kind enough to take a digital picture of the board and circle the transistors that need replacing in paint that'd be greatly appreciated. Also I'd need to know what transistors I have to buy and where I can get them. Apologies for my pedal n00bness.
Paul Marossy
QuoteSounds like your flip-flop circuit is busted.
Yeah, it kinda looks that way...
A flip-flop circuit is where a pair of transistors are used in place of a switch. A momentary switch activates the circuit, and one is off and the other is on. They flip-flop.
Say, are you sure that your battery is good? Sometimes those pedals don't work right on a low battery. But I'm sure you already checked that...
Kcollins
Yup, already thought of the battery. Same thing with a brand new 9v. It's wierd because it was working fine and I actually had the pedal sounding real good. Then It just decided to be stuck on "on" about 3 days later. If someone could inform me of which transistors need replacing  and where they're located, I could just replace them.
Kcollins
zac102
I can't find a schematic for your particular pedal, but in my ds-1, they're marked as 2SC-2458.  You should be able to locate them pretty easily by following the trace from the momentary switch.  I think you'd be able to get a suitable replacement from radioshack.  or, since it's already stuck in the always on position, you could get a 3pdt stompswitch and convert it to true bypass pretty easily.
