Slightly OT:Altoids Peppermint tins?
Started by Alpha579, January 26, 2005, 03:57:08 AM
Alpha579
'lo all,
I saw hals 'Altoids box distortion' over at http://www.geocities.com/halnotincluded/effects.htm, and i love the wee enclosure! but the problem is i cant find any altoids peppermints over here in New Zealand...what else can i use?
Thanx,
Alex
Alex Fiddes
MartyMart
Hi, you should be able to find some "similar" tins, try the "motorway service stations" they normaly have "drivers" mints or sweet tins.
Or a specialist "sweet shop" should have some.
Here's a few I've used, both sweet and candle tins.....
http://www.pbase.com/martymart/image/36094488
this one is 'altoids' and German sweet tins ( good size! )
http://www.pbase.com/martymart/image/38338965
The "Homer Drive !  a bit too big, biscuit tin !
http://www.pbase.com/martymart/image/38784370
http://www.pbase.com/martymart/image/38784373
"Easy Drive" in a candle tin ! perfect size for the jacks
http://www.pbase.com/martymart/image/39044090
http://www.pbase.com/martymart/image/39044093
"Brian may treble boost"  this "hot" mint tin is the same as the "altoids" tin --- very tight fit though !  ( ooh aarrr ;-) )
Good luck !!
Marty.
sir_modulus
Altoids are mints that are commonly available in the UK, Continental US, all over europe etc...
You can really use any little mint/cookie tin...it's just that altoids are just so good also....it's an excuse to buy yourself a few packs  :D
Cheers,
Nish
ethrbunny
Im assuming (naively) that on the larger 'tins' one would have to reinforce the lid somehow if there were a stompswitch present.. truth?
--- Dharma Desired
"Life on the steep part of the learning curve"
NaBo
but geez, i dunno why everyone buys the red peppermint kind...  wintergreen is the way to go  8)
sir_modulus
ROCK ON!!! Wintogreen is the ONLY kind I buy. Is that sturdy? I never tried putting a switch in before...
Cheers,
Nish
Hal
thanks, alpha :-D.  If you want, I could send you a couple for the cost of shipping...
NaBo
i used one of those cheapo x-wing dpdts!  they're perfect cuz the lugs are out on the sides, so it can rest against the bottom of the tin no problem.  my next feat will be a little double-booster in one of those tinier altoids chewing gum tins!  im just gonna use dpdt toggles, and have the battery strapped outside of the tin, use a male plug for the input, and it'll plug direct into my guitar!  might have to grind down some lugs here and there to make it all fit, but if nothing else it'll be fun to try, and i can always just put ONE in there if its a lost cause
