semi-OT: careless while painting enclosure
Started by nils, January 28, 2005, 02:16:40 PM
nils
Hi guys!
I was spraying an enclosure on my patio tonight and was a little careless. Some of the paint crept under the old papers I had layed out, and now I have some paint stains on a few of the stone tiles. What can I do to remove the paint?
"If you wind up with a boring, miserable life because you listened to your mom, your dad, your teacher, your priest, or some guy on TV telling you how to do your shit, then YOU DESERVE IT."
- Frank Zappa
bwanasonic
I would start with paint thinner or mineral spirits. In the US, we have a nasty little solvent blend called "Goof Off". Acetone is another to try. Good thing it's outdoors, cuz all this stuff is pretty nasty fume-wise. Abrasives might also work, but would most likely leave a mark. In general it's best to keep your solvent of choice and a rag handy for just such an occasion, as it's best to remove overspray when it's still wet.
Kerry M
smashinator
Alternately, just paint the rest of the tile, and glue some knobs on.  Tell everyone it's a Small Stone.   :shock:
Sorry, I couldn't resist.
People who say it cannot be done should not interrupt those who are doing it. - George Bernard Shaw
http://pizzacrusade.blogspot.com/
Nasse
:)  :lol:  :lol:
You need "graffiti remover" stuff
nils
thanks guys. I'll probably go for the "small stone" solution  :D
- Frank Zappa
Teflon scratch pad...might help
 experiment with steel wool in unnoticed spot at own risk
 Acetone [nail remover]...start with some in a spot on a rag and limit exposure...that's more for finishes, but acetone might cut it some, I don't think It'll damage tile surfaces.
Paul Perry (Frostwave)
Depends on what kind of 'stone' the tiles are.
Some materials are porous & if you try to dissolve the paint out it will get worse as pigment soaks in to some depth.
I would wait till dry, then try to scrape off, if it is material that can handle scraping. And  depending on how much is there.
Oven cleaner is worth a try if you don't want to buy special paint remover.
nils
it's indeed pretty porous; maybe the scraping off approach might work best.
- Frank Zappa
