GGG Regulated Power Supply
Started by Bassybert, January 31, 2005, 09:11:50 AM
Bassybert
I'm thinking of making this project. Can anyone please tell me if it's - or + grounding, or can I use both types?
Sorry for the basic question, but I don't have the schem in front of me at the moment.
Regards
James P
:shock:  :shock:  :shock:
Bassybert
What I meant to say was can I power both negative and positive grounded pedals with this supply?
James P
niftydog
Quotecan I power both negative and positive grounded pedals with this supply?
no.
Either build seperate ones of consider the Spyder.
niftydog
Shrimp down the pants!!!
ethrbunny
You could start with that circuit and modify some of the outputs to use the 'charge pump' from geofex. Look under 'circuit sweepings'.
--- Dharma Desired
"Life on the steep part of the learning curve"
