Phaser Fleur - chorus/(*)vibe sound?
Started by ethrbunny, February 01, 2005, 07:47:12 PM
ethrbunny
Im going to start building the phaser fleur as soon as I hear back from Dann on the commonsound board. Doing a search on this board indicated that the fleur can be used to make a uni/neo/easy vibe sound as well as a chorus. Truth? It has quite a few tweaks on commonsound so it wouldn't be outside the realm of possibility.
--- Dharma Desired
"Life on the steep part of the learning curve"
puretube
probably with the "staggered capacitors" trick - similarly doable with Small Stones...
ethrbunny
Quote from: puretubeprobably with the "staggered capacitors" trick - similarly doable with Small Stones...
do tell! I was thinking about building the easyvibe as well but will skip that if I can do it all with one board.
--- Dharma Desired
puretube
click the search button above,
type: " univibing " in the upper field,
hit the return key:
you`ll get 16 results (maybe 17, now)
which will tell you more...
ethrbunny
Thanks - knowing *what* to search for is the ticket.
--- Dharma Desired
