TS9 tone pot doing nothing!
Started by WorkBench, February 03, 2005, 10:13:31 PM
WorkBench
I have a TS9 that I modded to 808 specs.  It sounds good, but is to trebly.  The tone pot does nothing, but add hiss when I turn it up, and when all the way counter clockwise (which is where i have it) the effect is still too harsh and high end heavy.  Everything looks correct, and all connections are solid.  I have another TS9 that I can compare it to to check and the layouts are identical.  Any help?  Thanks!!!!
Chris
All good things in all good time
Transmogrifox
Is this modded on an original circuit board, or a home-built perfed project?
It almost sounds like you either got a wrong capacitor or resitor value in the wiper of the pot.  Maybe one end of the pot is connected to virtual ground???
That's all I can think of off the top of my head without seeing it.
trans·mog·ri·fy
