Schematic for XLR/balanced line driver?
Started by mikeb, February 17, 2005, 06:52:03 PM
Johan
..for what is worth...there is also something called impedance balancing, where you only feed signal on the hot side and has the other side ( the inverting side )being the same output impedance. often just using a resistor to ground.  That way, even though there is no signal in the inverting line, it picks up the same noise as the noninverting, resulting in canselation of cablenoise.
many times when you see small inexpensive mixers and they say something like "all outputs are balanced" this is how they do it. you loose 6db compared to active balancing but it does work...
Johan
DON'T PANIC
Paul Perry (Frostwave)
Right you are Johan, and that link from MikeB shows the details under 'cheat'. I was just meaning, tying one side to ground & just 'doing it', like when there is an emergency (the show must go on) :D
That balancing  cheat is a pretty handy trick!! thanks everyone!
Johan
Quote from: Paul Perry (Frostwave)Right you are Johan, and that link from MikeB shows the details under 'cheat'. I was just meaning, tying one side to ground & just 'doing it', like when there is an emergency (the show must go on) :D
..oops, sorry I missed that... :oops:  ..I'll go stand in the corner now..I should have read through the other replies first...
Johan
DON'T PANIC
