What to do when your pots are burning?
Started by cab42, February 17, 2005, 07:07:19 PM
cab42
Hi,
I just had the strangest experience. I was debugging my Tube Reamer, that didn't work, no sound at all, except for some scratching when I touched the strings.
I was working my way through the "what do you do.." sticky when I suddenly smelled smoke. I turned to my soldering iron to see if it touched something, when I turned back I saw smoke coming from the volume pot, and then it started burning and burned for a few seconds.
Well, I guess I found the error in the circuit  :roll:
Is it just a bad pot or can something else have caused it? Nothing else on the circuit board was hot or otherwise "strange".
Regards
Carsten
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
RjM
Check all of your wiring, including the wired that go from and to your battery or DC jack.
~Rj
Peter Snowberg
Another smoking pot thread. ;)
My guess is that there was a cap missing or a bad cap that was shorted in the circuit.
The scratching you heard from the pot was the same DC flow that caused the burning. This DC is usually blocked by a cap somewhere.
Eschew paradigm obfuscation
Paul Perry (Frostwave)
The only way a pot can burn (I have done it!) is if you have the centre connected to earth or a power rail, and one end of the pot to the power rail or earth (if you see what I mean..) Everything is OK until the wiper gets close to one end & the resistance across the poer rail to earth gets so low that an enormous current flows & that's it folks!
bwanasonic
Oh, I thought this was a post about that Midnight Oil song, nevermind...
How do I RAWK when my pots are burning?
Kerry M
cab42
Thanks for the info. Now I know what to look for.
I am building from Torchy's veroboard layout, but with parts taken from a perfboard tune reamer which I ruined when i tried to socket the diodes.
Is there a candidate to which cap i most likely to have been destroyed? I am quite sure that i don't have ant shorts between the traces. Maybe I just should by new caps?
I think the lesson learned from this is: If it ain't broke don't fix it.
Thanks again
Carsten
Ripthorn
cab42
Quote from: bwanasonicOh, I thought this was a post about that Midnight Oil song, nevermind...
Kerry M
Well, I actually considered give this as a title to the topic, as I also came think of that song. :) Great song by the way.
Carsten
Ripthorn
Mike Burgundy
suspect *any* cap directly connected to the pot. The trick is to never have DC on pots - they will scratch when manipulated and burn if the current is large enough
Caps should completely isolate the pot from any power supply voltage - usually Vref from IC outputs. A Volume pot is usually hooked up between signal and mass, taking the output from the wiper.
Make sure there is a cap before the pot, in series with the signal. If it is replace it, if there is not, put it there *now*
mojotron
As long as you don't inhale, you'll be fine - it didn't hurt that Clinton dude!  :wink:
