Fulltone OCD
Started by dosmun, February 18, 2005, 10:13:24 PM
Lurco
cd
A dental pick and some patience will have that goop off in no time.
stm
Seems there are a few components and a single/dual opamp only!
casey
how does a fella get a hold of some of that nifty goop?
Casey Campbell
stm
I think we need to add a new entry to the DIY dictionary:
Goop = Anti-DIY stuff   :(
Torchy
Outlaws
Quote from: TorchyShouldnt that be
Goop = Anti theft device ...  :?
Or...
Goop = Anti-Theft discovery device.    :roll:
I guess it could go either way by the sound of it huh?   :wink:
puretube
seems to be some non-conductive stuff, doesn`t it...  :?:
Torchy
casey
Quote from: puretubeseems to be some non-conductive stuff, doesn`t it...  :?:
yeah, and where can i find some?  i would like to use it for some of my pedals....
Casey Campbell
cd
Any hardware store, just buy the 5 minute epoxy.
casey
Quote from: cdAny hardware store, just buy the 5 minute epoxy.
i wont hurt any of the components?
Casey Campbell
Satch12879
It's called potting epoxy.  MG Chemicals makes a few different types (also copper-clad boards, pre-sensitized boards, developer, etchant, accessories, etc.) that are available from Mouser.  I just bought a 375mL set of clear potting epoxy that I plan on using but they also make a black and a blue some of which are thermally conductive.
Passive sucks.
Progressive Sound, Ltd.
progressivesoundltd@yahoo.com
stm
Be aware that use of potting may preclude fixing the PCB should it ever fail due to a damaged component or cold solder joint.   This is particularly true when you need to repair a board for someone who paid for it.
In my case, I prefer erasing markings on caps, ICs and transistors as a copy protection method. A lot of work needs to be done to reverse engineer it anyway, and there will always be uncertainty as of the semiconductors in use.
Of course goop has an "instant mojo" effect, such as: "if they took the time and effort to cover it, this must be really good and worth protecting!"   :twisted:
Regards,
STM
cd
Quote from: casey
nah, it's plastic.
 I add: and the only way I can ever have 'that' exactly is under the goop.
stm
Pete, I don't know if you are saying it as a joke or with a part of seriousness, but in fact the dielectric constant of the goop after it is dry could eventually take part in the overall effect, by means of increasing the pin-to-pin parasitic capacitances.
In case of a FF, this could effectively increase the Base-Collector capacitance, thus softening the sound. The same can happen between the negative input and output pins of an opamp.
As such, different goop materials *eventually* could alter the tone. I have the feeling that this may be subtle, but noticeable on high gain pedals where high-valued resistors are involved.
Regards,
STM
Well if it's gooped, an owner of a circuit has to think the technology inside can only be bought, and if all such circuits are gooped, that's the only way to have 'that'.
 Now, new question is about parasitic capacitences of goop, whether that's a joke or whether your perception is that the 'softening' or other circuit function goop may induce is 'good' or bad' or a little of both or...makes sense that it would 'change' the circuit to some degree, I notice these gainy circuits are pretty sensative as to what they are near when they are on...especially say my hand, many circuits 'change' considerably when a body gets within a certain proximity of it, goop would be like on it...interesting stuff, I'd never really thought about that.
Peter Snowberg
I think it should be pointed out that the goop is generally one of two major epoxy systems, as are FR4 circuit board binder, many capacitor, inductor, and resistor shells, and most transistor/chip packaging. :D
It's fairly inert stuff, but nothing is totally inert. So now how many pF get added to test circuit/layout X, once you cover it? Anybody have a lab-quality cap meter? :D I would love to know.
Maybe I'll start marketing a brand of boutique effects encapsulents with different dielectric constants. I can see it now...... "HarshAwayâ,,¢"  brand Goop. Available with dielectric constants from modern to vintage.
Here's some reading....
http://fame.sdsu.edu/student_research_dialectic.html
Notice the Hotel California-like architecture in the background. :mrgreen:
Eschew paradigm obfuscation
wampcat1
Quote from: stmMaybe the OCD is just a kind of RAT clone, as the Full-drive is a TS clone.  Just guessing here.  Can you point to where the picture of the unit is?  Are there any visible TO-92 trannies/JFETs besides the OpAmp?
Actually, I believe his other distortion pedal is a variation of the rat, if I'm not mistaken...
