Has anyone done a Diy flanger?
Started by Kcollins, February 25, 2005, 10:24:33 PM
Kcollins
If you have, where'd you get info on it?
ethrbunny
--- Dharma Desired
"Life on the steep part of the learning curve"
There are several Craig Anderton flanger projects posted at my site. http://hammer.ampage.org
You'll need to scroll down a few pages until you see "anderflange".  All rely on Reticon chips.
StephenGiles
......or the Mike Irwin modded ADA Flanger here:
http://img.photobucket.com/albums/v317/StephenGiles/ada_MI_1024.jpg
I've been using this flanger today with my accoustic and it sounds wonderful!
Stephen
ethrbunny
flanger with a _manual sweep_?!?? Be still my beating heart!  :shock:
What should I use for those op amps? Has anyone done a comprehensive shopping list for that spec?
--- Dharma Desired
StephenGiles
I used MC 3403 as per original circuit for input/output, but Mike Irwin suggested MC34074 which I havn't been able to locate yet. Without opening the case, I would guess a TLO74 for the LFO etc, but anything should do.
Stephen
ethrbunny
I dont suppose there is a chance you designed a PCB for this... is there?
--- Dharma Desired
StephenGiles
No, but someone does have a modded PCB for this. I build mine on veroboard.
Stephen
