Weird Boss Sd-1 led problem...
Started by jimbob, February 27, 2005, 03:38:33 AM
jimbob
I own a stock sd-1 that i changed out the 3mm led with a 5mm blue led but after a few hours the led seems to stop working. I use a 9v adapter. I took it out earlier and re solderd it and it worked again, but after a few hours it stoped working again. The pedal continues to work though.
Any ideas?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
toneless
Xm... I've made this to an Boss Metal Zone but I can't remember what I've changed. I think you may have to bypass a diode or use a bigger led resistor. :?  Good luck!
