Phase 90 - Bypass OK, but no sound when effect on...
Started by seekup1982, March 01, 2005, 12:12:31 PM
seekup1982
I just got a Block Logo MXR Phase 90 that I was susposed to add a small filter to get rid of noise.  I always plug them up before I mod them to see if they work.  And this one didn't.  The client tells me that he had it working last week (I believe him) but that he used a different +9V wall wart to power his board (using a Boss tuner and daisy chain).  Now, the signal bypasses just fine, but when I turn on the effect, there is no sound whatsoever.  Also the LED doesn't come on.  I metered the power out of my wall wart at 8.9v but when I put my DMM on metering the positive off the board (connected) it showed .24v.  I did have to cable ends plugged into the in/out to let the no connects to be triggered so that it should come on.  I don't think the power is susposed to sag that much, even if it is still connected.  Shouldn't I be metering something higher?  He bought it used and I can see that the 4 phasing transistors were replaced and R22 was replaced with a 2.2M (instead of a 3.9M I think).  Does anyone know what might be causing this system not to work?  I don't have the pinout values yet, but still any help would be great.  How do I get the pinout values?  Just clip (-) to ground and touch (+) to the pins?  Thanks.
Ben
yupp try touching R and B in Beep mode,,,you should hear a beep...
 Clip black to known ground, then check all grounds.
 Switch to 20v range on the meter, start at OA 1 Pin 1, write down the voltage and repeat for all the other opamp pins.
 Check out the debugging page, and: "What do I do when it doesn't work?' [a 'sticky' at top of forum listing]...try audio probing...I usually probe after I sort out the pin voltages...but I just use my 'thumbuzz Technique'...starting from output, working my way through the signal path toward input...you should hear a buzz sound when your thumb is connected to points in the signal path...if the noise is 'broken' at some point in the SP, that's where I'd look for a problem.
 You'll need to connect to a live amp and use a probe to connect your thumb to circuit points...but if you're reading a big voltage drop...you alluded to sag...I'd figure that out first using pin voltages as a guide.
seekup1982
What does "R and B" stand for?  Thanks for your whole post and tonight I'm going to find the pinout values.
Ben
Vague there...sorry
 The Red and black multimeter leads..
seekup1982
I just got an email from Dunlop's tech guy and he said that my friend probably used the wrong adapter (I didn't even tell him that!) and that I should replace the power diode (1N4148) and if that didn't work, replace the ICs.  He was very surprisingly helpful.  Anyway, I'll keep you updated.
Ben
seekup1982
Fixed it last night!  The problem was that he did use the wrong adapter.  The diode fried and luckily that was it.  I figured it out last night when I had hooked up a fresh 9.24v battery to it and after 10 minutes it got really hot and was only 7.81v.  Obviously it was like I was just shorting the battery.  Found out quick one 1N4148 diode was bad, put a 1N914 in its place.  Is this the right replacement?  Or should I use a 1N4001?
MartyMart
1N4001's are more commonly used as "power protection" diodes, it will "protect" a bit more than a 1N914 ! ( which conversely will "blow" easier )
Cheers,
Marty.
