Sparkleboost build problem
Started by adgators89, March 03, 2005, 12:07:24 AM
adgators89
I tried to build the sparkleboost, but all i get out of it is a broken up fuzz sound.  anybody have this happen to them?  any possible fix?
Dragonfly
Quote from: adgators89I tried to build the sparkleboost, but all i get out of it is a broken up fuzz sound.  anybody have this happen to them?  any possible fix?
well...we need more info...
which layout did you use (or did you make your own) ?
which fet are you using ?
did you check the pinout and verify it's orientation ?
is the fet biased properly (4.5v) ?
any parts substitutions ?
adgators89
I followed the schem that you posted.
in to .o022u to transitor socket.  2.2m resistor inbetween the in and the cap going to ground also.  and then 1m resistor going after cap to ground.
where you have listed the 100k trim, is that a pot, or just a 100k resistor.  if it is a pot, is it audio or linear.
I used theNTE458
no part substitutions
I  can not find my mulitmeter as of now, so I can not test for bias (don't really know ho to do that anyway)
any help would be appreciated, thanks
Dragonfly
Quote from: adgators89I followed the schem that you posted.
sounds correct so far...assuming you meant .022u cap, not .0022u ...
its a 100k trim pot. its used to adjust the bias. alternately, you could wire up a 100k linear pot as a variable resistor (connect lugs 1 and 2 together, then connect lug 3 to the battery 9v+, and lug 2 to the "drain" of the fet), set the fets "drain" voltage at 4.5v, measure the resistance, and use a regular resistor of that value in place of the trim pot...but its MUCH easier to just use a trim pot in the first place. :)
I used theNTE458
good...thats the fet i designed the circuit around....
if you didnt use a 100k trim pot, than there "is" a substitution...a VERY important one at that ! Different fets need different resistance values to bias proerly, and a 100k resistor will rarely be the correct resistance.
heres how.....
..with a fresh 9v battery hooked up, and a 1/4" plug in your effects input jack......
1)get your multimeter and set it to 20 volts.
2)take the black probe of your multimeter and touch it to ground
3)take the red probe of your multimeter and touch it to the "drain" of the fet
the reading you get will be your voltage...often, you'll get a 0v reading...slowly turn the trim pots dial while watching your multimeters reading carefully. the voltage reading should eventually register, and you want the final reading to be 4.5v
if your voltage is too low of too high, you'll get a very low, fuzzy sound, and very little actual boost...much like the sound you described.
get the 100k trim pot installed and bias the fet following the directions above...and keep me informed on whats going on :)
Best of luck,
Andy
Dragonfly FX
adgators89
ok, have to get a 100k trimpot and I'll go from there tomorrow.  I will let you know the progress after I try that
Dragonfly
Quote from: adgators89ok, have to get a 100k trimpot and I'll go from there tomorrow.  I will let you know the progress after I try that
great !  i think it'll probably solve your problem...
andy
dragonfly fx
adgators89
yeah, it works now, I got the trim pot today and it worked right away.  the volume pot definitley works.  However I seem to have some problewms yet
1)  it seems that the other 5k linear pot doesn't do anything.
2)  overall I think it actually loses volume though.  a
any suggestions on what to tweak or do from here
Torchy
adgators89
ok, that would make sense then, I am playing through a ss amp at home, but I use a marshall tsl jcm2000 tube amp for live gigs with the band
I'll have to check it out through that amp as well
Dragonfly
Glad the trimpot issue solved it for you. As mentioned, the "gain" knob has far more effect when driving a good tube amp...with a solid state amp its fairly "subtle" effect...
on a tube amp, man, its beautiful :D
let me know how it works with your JCM2000....
Andy
Dragonfly FX
Alpha579
andy, have u ever tried removing the 2M2 res from the input? because it doesnt seem to be doing anything useful, it will drop input impedance very slightly....and what about replacing the input cap with a 10K res, make sure RF breakthrough will never be a problem...just some thoughts  :)
Alex Fiddes
Dragonfly
Quote from: Alpha579andy, have u ever tried removing the 2M2 res from the input? because it doesnt seem to be doing anything useful
pop protection on true bypass...the pot sends any stray voltage to ground at the end of the circuit, the 2m2 sends it at the beginning....thats the "only" reason its there :)
havent tried it...the cap blocks any stray dc voltage from entering the circuit, but thats about all it does at that point in the circuit...i might try building one with a resistor up front instead of the cap, see what kind of difference it makes...but to tell the truth, i'm 100% happy with the Sparkle Boost circuit "as-is"  :D
Alpha579
Quote from: Dragonfly
well as of my knowledge, theres no dc bias on the gate, so pop prevention is unneseccary, as theres no charge on the cap...and the likely-hood of having stray dc on the output of another circuit is highly unlikely, and any that does should be scrapped imediately :wink:
Alex Fiddes
Dragonfly
while i realize this, the reality is that a cap costs a few cents, so having the extra protection is worth it to me...  :)
adgators89
allright, I drew up a little layout that I made of my perfboard for a visual.
hopefully this will help diagnose any problems.  I used all the values that you had listed in the schematic.
the address is here
http://www.geocities.com/adgators89
Dragonfly
Quote from: adgators89allright, I drew up a little layout that I made of my perfboard for a visual.
the address is here
from what i can tell by the drawing, your layout should be fine...try touching up all the solder joints (esp to ground), quadruple check your pinout (DGS, flat side facing you), and make sure that the polarities of the electrolytic caps are correct....the sparkle boost, if built correctly, will give a TON of boost...so somethings not right if you arent getting a good solid boost from it.
have you checked the fets voltages at eack pin ? if so, what are your readings ?
Andy
adgators89
is that 20 volts ac or dc ( remember I'm new to this, never used a multimeter before)
adgators89
on my multimeter, It reads 10 then 50 then 250 then 500, those are my only choices, I do not have a setting for 20.
is there any other settings I could try?  I have no clue how to use this thing
Dragonfly
Quote from: adgators89on my multimeter, It reads 10 then 50 then 250 then 500, those are my only choices, I do not have a setting for 20.
"10" will work fine for biasing/reading the voltages on the fet :)
adgators89
where is the "drain" of the fet - is it after the transitor and before the 100k trim pot?
