CA3080E
Started by smallbearelec, March 04, 2005, 01:45:50 PM
Transmogrifox
thanks again.  I've been tweaking around, and have not yet successfully diminished the low-level feed-through.  At least I got rid of the distortion.
I think I will be making a PWM VCA attempt here to see if I can make a volume swell based on that.  I'll post a schematic if it works.
trans·mog·ri·fy
puretube
#21
Transmogrifox
That seems like a promising approach.  I just posted in a new thread:  the PWM circuit was exactly what I was looking for.  It works beautifully with an LM339 if I keep the oscillator Frequency down at 22 kHz.  Wonderful resistance range, and perfectly dead extinction at minimum.  I think this will make a good base for the string swell effect.
trans·mog·ri·fy
puretube
#23
zachary vex
Quote from: R.G.I hate to mention this, but a working OTA can be made from ten transistors and no other parts. Only one matched pair is strictly needed, but a four pairs makes it all dandy.
There are no passive parts in an OTA except conductor metalization.
Shoot, maybe I should whip up an all-transistor OTA replacement board for the CA3080. I suspect that with surface mounts, it might be not much larger than the 3080.
But Mark's right - look for LM3080.
show us.  we may need that knowledge evenutally.  8^)
puretube
#25
MartyMart
Well the shortage hasn't hit yet, "RS components" UK has them for less than £1 each and Olaf at "BanzaiEffects" has CA3080E's for 0.54 euro's each !!
Just my 2c worth.
BTW: That 1974 article is great information, thanks puretube :)
Marty.
