ot calling tube amp gurus...R.G??
Started by swt, March 05, 2005, 01:05:36 AM
swt
Maybe this is a stupid question...but...can i try parallel diodes like in the big muff, with isolating cap, and maybe a series resistor, with a preamp tube, to achieve kind of an overdrive sound?. Or should i stick to the traditional diodes to ground?. What i mean is back to back from plate to grid, with series cap and resistor. Ideas for the resistor value??. Can i damage the tube??. Thanks a lot for any replies!!.
Ps: i tried this in a bluemagic to get more drive, and it works perfectly with fets, provided the blocking cap.
Peter Snowberg
Grid current is really small so as long as you don't have a DC path from the plate to the grid, and the coupling cap in series with your plate-grid diodes as well as the diodes themselves can handle the voltage you should be just fine.
Because the signal is much larger, try zeners in series. :)
Eschew paradigm obfuscation
swt
Well Peter...Thanks a lot!!!. I'll try it and let you know how it worked out.
Peter is correct in many respects.
To make this work properly, you need a series resistor going into the grid and your feedback network also connecting to the grid. Leave off the 470K feeback resistor or capacitor couple the whole mess - no plate DC voltage back into the grid.
When you do this, the tube-y-ness largely vanishes, as the feedback diodes are now the determining factor in the output. And the output is limited to the +/- diode drop that the diodes let the plate move.
swt
Thanks R.G!!. i've already tried it, and i didn't like it. You are right, it lack the organic feel of the tube. I've also tried the tut 1 method and didn't like it. So...i'll have to tried more gain stages and interstages attenuators to get the sound i'm after. Thanks for your kind replies fellas!!
