two things that have been bugging me....
Started by Toney, March 05, 2005, 08:14:12 AM
Toney
Hi,
Any opinions re advantages with enclosed shielded jacks or are open style perfectly fine with most stomper builds??
And...have mounted a couple of things with double sided foam tape.Any possibility of unwanted capacitance through contact with the tape surface?
That sticky stuff is touching a couple of traces due to tiny board.
Thoughts?
rubberlips
I use insulated stereo jacks on the input of the effect to avoid ground loops, and to cut off the negative for battery life.
You could use normal ones if you like, just avoid ground loops
Pete
play it hard, play it LOUD!
