Understanding a datasheet
Started by ethrbunny, March 05, 2005, 10:04:36 AM
ethrbunny
Ive been working (struggling) to understand some problems Im having with the ISD2560.
Two big questions:
1) why are there 2 different +5 inputs to the chip? The datasheet says "single +5V power supply" yet there are 2 distinct (analog and digital) lines. Does this mean I need to supply two distinct 7805s?
2) these lines are supposed to be 'decoupled as close to the pin as possible.' Does this mean I should trim off extra wire from the capacitors? How close should I be aiming for? Can I use a common ground for these?
--- Dharma Desired
"Life on the steep part of the learning curve"
toneman
page 7.
Vcca is analog power
Vccd is digital power
chip maker elected to keep them separate.
also watch out for analog & digital *gnd*s.
keep them separate until U tie them 2gether *at only one point*.
this would B @ the pwr input 2 the pcb.
staysampled
tone
ethrbunny
So making them common through the whole board? no go?
EDIT: on the sample page the grounds *appear* to be common. There is a single line Vcc for feeding both the Vd and Va.
Im way confused.
--- Dharma Desired
Paul Perry (Frostwave)
I wouldn't worry about it too much.
You only need one 5v regulator.
For this kind of thing, the separate grounds & supplies are only important when you are getting the last bits of noise out of the system, & it will only matter if the PCB layout is pretty well 'optimum', which is unlikely to be the case.
I don't think it would be worth cutting legs off caps either.
ethrbunny
Ok. Im asking as Im getting terrible noise on mine. The chip is recording and playing back ok but there is a strong background hum with several periodic elements. Makes me wonder if the chip isn't properly 'decoupled'.
--- Dharma Desired
