questions about effect loop of the Pt-80.
Started by mathflan, March 05, 2005, 10:30:17 AM
mathflan
hi,
I'am asking some questions about the effect loop of the Pt-80 from the site
http://www.moosapotamus.com/pt80delay/PT80effectloop.gif
first
Is the send jack is a stereo jack??
The pin 7 is tl072 is the pin which goes to the capicitor of 470 pF??
On the shematic :
I don't understand where to solder on the 6 pins of the switch.
Where do I have to solder the ground of the send and return jack?
http://sounddiy.free.fr
NaBo
QuoteIs the send jack is a stereo jack??
No, it's a closed circuit mono jack.  It has a metal piece that connects to the tip when nothing is plugged in.
QuoteThe pin 7 is tl072 is the pin which goes to the capicitor of 470 pF??
Yes, pin 7 is pin 7...  :wink:  ...   hold the IC so the circle/notch is at the top, and pin 1 is to the left. then count 1-8 going counter-clockwise
QuoteI don't understand where to solder on the 6 pins of the switch.
the lugs...?  :P  what do you mean?  each little circle is a lug... left side from top to bottom you can call 1,2,3... right side 4,5,6...?
QuoteWhere do I have to solder the ground of the send and return jack?
Anywhere thats grounded!  :)
mathflan
Hi,
CAn you just verify this layout please:
thanks!
