Tubescreamer bias resistor for second half of op
Started by Ghandi, March 11, 2005, 12:49:06 PM
Ghandi
Is it a must or not really necessary?
The son of screamer doesn't have one and the boss sd-1 has the 0.018uF cap connected to V/2?
onboard
Which SD-1 schem are you looking at? The one I just found shows the .018uf cap to ground, with a 10k to V/2.
I don't have a schem for Jack's Son of Screamer, so I don't know.
-Ryan
"Bound to cover just a little more ground..."
Ghandi
I'm looking at phillips schem on fuzzcentral
and I found that this is correct opening a sd-1.
onboard
I was looking at the distortion section over at GM Arts.
Not calling you on it, just pointing out my reference.
Hmmmm....you opened a box and checked - that just seems wierd to supply bias voltage through a small cap....
Sorry I can't help you on that one  :(
-Ryan
Ghandi
Yeah,
I saw the shems but they are not really accurate!
