opamp gain question
Started by Marco Pancaldi, March 17, 2005, 08:18:07 PM
Marco Pancaldi
Hi,
in opamps, the clipping behaviour is absolutely and only dependent from the rail-to-rail powering? In other words, if I overload the opamp sending too large signal to the input or using a too large feedback gain the clipping is the same (for the same "desired" voltage level)?
For example, in a Tube Screamer circuit, to use 4x booster BEFORE the opamp give exactly the same effect as using a 4x feedback resistor (I'm ignoring here all the details about feedback resistor values)?
And is this true for both non-inverting and inverting circuits?
Many thanks.
brett
My *guess* would be yes, the effect would be the same, because the signal level for all components in the op-amp except the input stage would be equal.  Experts?
Brett Robinson
loscha
that is pretty much how my lecturer explained it the other day to us.
input signal voltage or feedback train --- all dependant upon rail to rail voltage.
Of note is maximum current draw vs feedback resistors. You want to keep the resistors somewhere in the realm of not drawing too much current, but that shouldn't be a problem in a practical circuit: Only theoretical "for argument's sake" circuits.
which part of sin theta plus index times sin theta times ratio do you need me to clarify to you?
