Quick and stupid Veroboard question
Started by crawler486, March 22, 2005, 09:37:04 AM
crawler486
hilbi
they are simply breaks in the circuit.
just break the copper wire at the red boxes.
hilbi
Built so far: PNP FuzzFace, MXR Dynacomp, EA Tremolo, AMZ Mosfet Boost, AMZ Super Buffer, Blue Magic, Peppermill, RM Axis Face, Sparkle Boost, BSIABII, ROG Ruby, AMZ Mini Booster, MXR Phase 45 Univibe, Tremulus Lune, Dallas Rangemaster, Ross Comp
crawler486
AHHH I see!!
Ok many thanks hilbi  :D  :D
Tht's where you drill the trace, 'ending' it. Some use dremel, I like the drill bit idea...get a wider diameter drill bit than the trace is wide, and drill just deep enough to end/eliminate only "that copper trace  ..EZ.
 The strip should no longer conduct across the little red squares.
crawler486
Quote from: petemooreTht's where you drill the trace, 'ending' it. Some use dremel, I like the drill bit idea...get a wider diameter drill bit than the trace is wide, and drill just deep enough to end/eliminate only "that copper trace  ..EZ.
thanks petemoore I was gonna ask the best way to cut the traces
