need big muff help
Started by Bruce A, March 28, 2005, 01:28:52 PM
Bruce A
:roll: I recently purchesed a Big Muff USA reissue that was rehoused in a nice little Hammond box. In an attempt to switch the AC power supply connector to a Boss type, I inadvertantly disconnected the wires. Can anyone tell me how and where to connect the ground and the hot leads from the AC power plug? Thanks.
aron
Ground can be any ground pad. Use your meter on continuity and buzz the points to find ground. Find the obvious looking "large" areas that should be ground. Put the black probe on the metal housing and use the red to probe and find ground.
The positive should be any place that the collector resistors "connect" to.
This is in reverse if it's a negative ground circuit. I don't know what the USA reissue is off hand.
