LDR from Small Bear for Neovibe
Started by optimus_prime_1985, April 05, 2005, 03:15:50 PM
optimus_prime_1985
Hey guys,
 I ordered 4 LDR from SB for my neovibe project. The ones that came in the mail are the small ones that look like a solar panel or a radiator. All the pictures I have seen on the neovibes have the round metal enclosed LDR. I ordered the one that he says is for the Neovibe/Univibe. There is no picture on his site of this item so I wanted to check with you guys first if these sound like the same ones before I e-mail SB. I know he has been busy and it may be a couple weeks before I get them swapped out if these are not the ones. Thanks guys.
Karmasound
FWIW
I ordered the same ones and that is exactly what mine look like.
I'm betting they are the right ones 8)
littlegreiger
Can either of you post some pictures?
MartyMart
That's correct, you have to line them up against the top of the LED, flat topped LED's work fine, tiny dab of superglue or any totally transparent glue will do.
Instant LDR/LED combo !
Cover the whole thing in cable shrink/thin black foam if you need isolation like the EZVibe does.
Marty. 8)
Karmasound
Don't you have to use  a lamp bulb in the univibe?
