new design to test
Started by j0shua, April 06, 2005, 07:26:59 PM
j0shua
This is a high gain distortion prototype.... ideas and sug. mod's wellcome
http://www.freewebs.com/teknoblaster/octomonster.jpg
please copy and paste !
another schematic prototype
http://www.freewebs.com/teknoblaster/blackrainmagic.jpg
please copy and paste in other windows browser
j0shua
so , no coments......
come on guys !
ninoman123
They dont link to anything joshua, just returns back to the thread
toneman
its a loop.......
loop....
loop....
endlesslyloopingendlesslylooping....etc
NaBo
Quote from: j0shuaplease copy and paste in other windows browser
You guy's really are DIY, don't even follow directions  :wink:
His host (like many free ones) doesn't allow direct links to files... presumably so people won't just use their space to host files, like we all do anyways :)
j0shua
as NABO says you need to read heheheheheheheheheheh
i put 2 times "PLEASE COPY & PASTE "  lol!
j0shua
so no coment's, mods or sugestions??????
ninoman123
I read schematics, chemical equations, and quadratic formulas. Simple sentances are last on my list.
ninoman123
Looks like the Black Rain's bypass transistor needs to be flipped 180 degrees. You want the power to go into the emitter, its going to the collector on yours. Also on the Black Rain...and correct me if you think this is wrong, but shouldnt u have somewhere like a 2k or 1k for the gain on the 386. I think the most useful range on those is with a 1-2k. At least in my experience. All of your other pedals use 2ks. Octomonster looks good.  :wink:
NaBo
Quote from: ninoman123I read schematics, chemical equations, and quadratic formulas. Simple sentances are last on my list.
LOL, you and me both...  unfortunately im an english major...  :roll:
Speaking of that... "sentEnces"  :wink:
Quote from: j0shuaso no coment's, mods or sugestions??????
... I like your drawings  8)
j0shua
to Ninoman123:
yes 1 or 2 K for Gain pot .... 5k was error ...thanks, and the Transistor is now fixed .... thanks!  :lol:
j0shua
to Nabo: thanks .... :)
remember any mod or idea is wellcome :) i like to share my draws , i hope to build those things on weekend
demo sound come :)
j0shua
ok guys better to see here :) and check my new BIG BANG BOOSTER
Easy to build sound demo tomorrow
enjoy
j0shua
ooops  :oops:  i forgot the link heheheheh
http://aronnelson.com/gallery/album02?page=2
enjoy!
{ antonio }
joshua
what program are you using to create your schematic/pcb board look?
thanks.  antonio.
shalom + godspeed.  antonio.
www.myspace.com/magnificat
j0shua
Quote from: { antonio }joshua
thanks.  antonio.
PCB WIZARD :) really easy and faster
j0shua
sound demo of Booster arrive in 2 hours :)
Dragonfly
Quote from: j0shuasound demo of Booster arrive in 2 hours :)
Joshua...
in your BigBang boster drawing, it shows a switch going between 2 input caps....but you have both labelled as .01uF, so it wouldnt matter which way it was switched, it'd sound the same....
you might consider something like a .0068 (similar to a rangemaster (.0047) on one side, and somewhere between a .01-.1 for the other...or even better, either a "blend" (like Gagans easy face), or rotary....
also, is it biasing with the 560k off the emitter ? normally in a circuit like this, which is essentially a LPB circuit, you'd see someting like a 220 ohm-560 ohm, depending on the sound desired...especially with a 10k to collector. You could also use a 1k pot instead of a resistor off the emitter....and even a electro cap off lug 2 of the pot, like a FF would ude...it'd give you far more boost capabilities, and in the "upper levels" of boost, probably overdrive quite nicely....
just some thoughts...
Andy
j0shua
Quote from: Dragonfly
Joshua...
Andy
OHHHH  I FORGOT TO PUT LOL.... OTIGINAL VALUES ARE 0.33uf AND 0.68uF
LOL.....
Thanks Andy
BTW check the others effects..... octave-dst. works in theory , and blackrain is 2K on DRIVE POT NOT 5K
j0shua
Ok guys this is de sound demo of the booster
PLEASE COPY AND PASTE THE LINK IN NEW WINDOW BROWSER
http://www.freewebs.com/teknoblaster/booster.mp3
