Si Tonebender MkII questions
Started by dv8, April 08, 2005, 03:02:58 PM
dv8
I built a Si Tonebender MkII from RDVs site: http://mysite.verizon.net/res0o2zg/sitebuildercontent/sitebuilderpictures/sitonebendermk.jpg
I used a 2K trim for attack. Q1,Q2 are 2n3904 w/ ~210 hFe, Q3 is 2n5088 with ~400 hFe.
It seems very distorted, really crunchy when cranked.  It does sound like the TB on homewrecker.com site.
It cleans up, rolling the guitar volume quickly (like by 9-8.5).  I don't have a Tonebender to compare it to, is this normal?  And is loads of crunch normal too?
I was think of having this circuit parallel with a Tube Reamer and have a pot to mix the 2 distortions sort of like the Roseyray w/o the filtering.  Any ideas?
brian wenz
Hello Hello--
     Try putting a 1K attack pot in there instead of the 2K  and see how you like the sound and response.  The bias for Q3 changes if you mess with that pot value.
Brian.
dv8
I thought I had a 1K and 2K pots, I started looking through my supplies and I didn't have either.  I had to use a 2k trim just to get this thing going.
thanks for the suggestion.
-brian
