BSIAB2 Mods
Started by mojotron, April 11, 2005, 11:17:03 AM
hilbi
I tried the C6 cap mod (used two ceramic 150pf's paralel).
I like this mod, it decreases the bass a bit and it is a little less ooomph, without loosing the power.
hilbi
Built so far: PNP FuzzFace, MXR Dynacomp, EA Tremolo, AMZ Mosfet Boost, AMZ Super Buffer, Blue Magic, Peppermill, RM Axis Face, Sparkle Boost, BSIABII, ROG Ruby, AMZ Mini Booster, MXR Phase 45 Univibe, Tremulus Lune, Dallas Rangemaster, Ross Comp
bwanasonic
Quote from: PhorhasBTW, using the first stage as a booster, is really SWEET
(In case you didn't know):
This is otherwise known as Jack Orman's Minibooster and is the original basis for the BSIAB.
Kerry M
hilbi
My BSIAB II doesn't react very well to a wah in front of it, I can hardly hear any wah effect. It is the same as a fuzz face after a wah.
Did anyone experience this? Any idea what to do about it?
hilbi
Phorhas
Quote from: bwanasonic
Kerry M
I did know, and I'm very fond of jack's MB. I meant that in the particular set up of trannies and resistor/cap values it gave exellent tone, to my ears... somewhat diferant to the "stock" MB
Electron Pusher
Ed G.
Quote from: Phorhas
Kerry M
That first stage is set up to sound very tight, and not 'flabby' as the stock setup on the neck position, lower strings. I haven't heard it by itself, but I imagine it'd make a good treble booster.
Phorhas
Indeed it is... :) just needs a bit of hi-cut filtering in the end and maybe a bit more bass output. It's pretty powerful with the 2N5457 pair, which quite surprised me.
Electron Pusher
hilbi
QuoteMy BSIAB II doesn't react very well to a wah in front of it, I can hardly hear any wah effect. It is the same as a fuzz face after a wah.
Would adding an output buffer to the wah solve the issue with the bsiab?
hilbi
Ed G.
Should be easy to find out. Just stick a Boss pedal in bypass mode in between the wah and BSIAB.
I find in general, wah transients decrease with distortion, mainly because distortion compresses those dynamics.
hilbi
ok thanks Ed, i will try that.
hilbi
hilbi
It is indeed the wah with no output buffer wich is the problem. I f i put a boss pedal between the wah and the bsiabII the wah effect is ok. Also if i don't use the bos pedal in between but i activate f.e. the dynacomp compressor (in between) it is also ok.
So it looks like the bsiabII needs a wah with output buffer before it, otherwise there is hardly any wah effect.
hilbi
hilbi
I searched the forum, but i did not find anyone else with this wah/bsiab2 issue. Am I the first one? Or does everybody use wah's with output buffers or a  buffer in between?
Also another question, is there a mod to increase the mids in the bsiab2?
hilbi
toddebner
Quote from: hilbiI searched the forum, but i did not find anyone else with this wah/bsiab2 issue. Am I the first one? Or does everybody use wah's with output buffers or a  buffer in between?
You could add a buffer to the front of the BSIAB design.  Use an opamp or an NPN.
Quote from: hilbiAlso another question, is there a mod to increase the mids in the bsiab2?
Could you use Jack Orman's Version 2 AMZ Tone Control ?  It looks like by adding in the body control it gives more midrange as well as a better looking overall response.
http://www.muzique.com/lab/tone3.htm
I haven't tried this yet, but am thinking about building the BSIAB II pedal.
What do you think ?
hilbi
Thanks toddebner,
I fixed the issue by adding an output buffer to my V847 wah. It is the outputbuffer that is available from  http://fuzzcentral.tripod.com/mccoy.html
This wau it also fixed my wah issue with my RM Axis Fuzz.
Kill two birds with one stone  :wink:
I sure can recommend you the bsiab 2, it is a great heavy overdrive pedal.
hilbi
