Changing pot values in wah cases
Started by mrsage, April 11, 2005, 06:31:33 PM
mrsage
I'm sure this has been addressed before, but I can't find any threads on it...
I want to build a Kay Fuzztone and put it in a Crybaby case. The problem is that I need a 50k pot for it, and the pot in the crybaby case I found is 500k.
Seems like this has to have come up before...What's the best way to get a different valued pot to put in there? I opened up the old pot, and it doesn't have a wafer I can try to swap out.
Is there a place that sells wah/volume pots of different values? Or can I get a different kind of pot and somehow attach a pinion thingie to it?
leonhendrix
mabey u could use this, click on linear pot and it will tell you how to get a desiered value. http://www.diystompboxes.com/analogalchemy/emh/emh.html
leon
mrsage
Pedal love
Thats the cool thing about a crybaby case, you can put almost any circuit in there.pl
Yupp like a phaser with speed control on the treadle.  8)
Pedal love
Quote from: petemooreYupp like a phaser with speed control on the treadle.  8)
That'll be my next project 8)
walters
3 ways to do this
1.) to try to take off the shaft gear off the 500k wah pot and put it on the 50K pot
2.) or to use the 500K and put a resistor on the wiper and one side of
    the pot. You have to cal. it out to find the resistor value in parallel
    with the 500k pots wipe to make up 50K.
   a.)  try putting a resistor across in parallel the outside terminals of the pot not the wiper terminal
   b.) and then put another Resistor from the one of the outside terminal
        and to the wiper u have to cal. it out
        or the best is what i do is hook up 2 substitution resistor boxes
        to find these 2 resistor values and try to get 50K
    c.) This will give u a Different Taper for sure but its a close as i
         can get
walters
You can redesign the circuit so its based around the 500K wah pot
just use the same schematic path ways and parts but would
all be different values to be the 50k pot now be 500K to be redesign
to it
puretube
I like that way of looking at things...  :wink:
