ExpressSCH problem
Started by school, April 17, 2005, 04:28:12 PM
school
how do you number the JFET pins in SCH? anyone?
littlegreiger
Do you mean label, like D S G? If you do all you have to do is select the text tool on left side toolbar. Then type the letter in the box at the top right and click where you want it on your schematic.
bwanasonic
You have to ungroup the part and number/ label each pin (under "component" menu"). Then regroup it into a component.
Kerry M
school
bwanasonic
Quote from: littlegreigerall you have to do is select the text tool on left side toolbar.
This does not number and label the pins for use in ExpressPCB. If you want to use the .sch file with ExpressPCB, you need to follow the above procedure (ungroup/regroup).
Kerry M
bwanasonic
Quote from: schoolwell, it says its an error
You will get an error if you click in the schematic with the text tool before entering text in the toolbar at the top. You type what text you want in the toolbar, then click where you want it. You can then double-click the type you placed to edit it.
Kerry M
Gringo
IIRC, you first have to ungroup the component, and then double click on the pins, and set the pin number. After you've done it for all the pins in the component, just regroup.
HIH
edit: oops, bwanasonic beat me to it :)
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
school
damn, you actually have to lay out your own boards in express PCB? someone should make a program that does it all automatically, just upload the schematic and BAM!! a PCB.
object88
That's a very difficult thing to make a computer do well, school.  IIRC from some previous threads here, some companies do make spftware that auto-routes circuits, but it's very expensive.  Give it a few years or decades, and we'll have it for cheap.
bwanasonic
Quote from: object88Give it a few years or decades, and we'll have it for cheap.
Give it some time and you'll know how to do it yourself!  :wink:  :D
Kerry M
