New design, it's been awhile
Started by joegagan, April 19, 2005, 04:31:56 AM
Ry
I think I have it working, but I want to address one issue I'm having before I post a build report (because it may not be working the way it should).  This is really odd, but the pedal does not pass a signal (bypassed or otherwise) in channel 1 of either of my amps.  Both amps are Fender.  One is a '64 Princeton, the other is a '79 Vibrosonic Reverb.  Both amps work with the pedal going into channel 2.  Both amps also work fine with just the guitar or any other pedal plugged into channel 1 using the same cords as with the Decade.
What the heck is going on?  The Decade works fine going into my Pod with the same cords as well.
Any ideas?
Steben
No DC blocking cap in the input of channel(s) 1?
Ry
Looking at copies of both schematics, the only difference is that channel 1 has a 1M resistor hanging off of it going to ground, channel 2 does not.  There is no DC blocking cap on either.
