Electrolytic Cap Question
Started by robotboy, April 21, 2005, 01:43:21 PM
robotboy
Can you use electrolytic caps in a schematic where a cap is specificied without polarity? If so, does the orientation of the electrolytic cap matter?
dpresley58
Check the DIY FAQ... This little ditty was cut and pasted from  it...
QuoteCapacitors - Can I put a non polarized capacitor in place of an electrolytic (one that has plus and minus signs)?
Yes you can. It's more troublesome to do the other way - to put an electrolytic in place of a normal capacitor since you have to orient the capacitor the correct way or bad things could happen. Don't do this on high power circuits though. For most 9V stompboxes, this should be fine. How do you know which way to orient the polarized cap? The connection point with the larger voltage faces the positive side of the cap. (Use your meter)
Lotsa cool stuff there.
Little time to do it right. Always time to do it over.
