Simple distortion for bass guitar
Started by shawsofhell, April 22, 2005, 05:28:21 AM
shawsofhell
I want to build my bass player a pedal. I was thinking the bazz fuss but don't know which variation to build of it (original version? home-wrecker version? buzzBox?)
Any other suggestions?
Ge_Whiz
GGG Op-amp Muff Fuzz:
http://www.generalguitargadgets.com/index.php?option=content&task=view&id=26&Itemid=94
1uF input cap, 10uF output, +ve towards IC. Two germanium diodes or one germanium, one silicon for best results.
MartyMart
The "Electra" distortion is quite nice, its in Torchy's layouts, very simple
just add a 100k vol pot on the output and use bigger caps for C1/C2, say
between 0.22's to 1uf polys .
Should work fine for bass, its only 9 components !!!
Marty. 8)
moosapotamus
Of all the Bazz variations, I prefer the Buzz Box for bass. But, the original version is good, too. The original is a bit rough (nice) sounding, and the Buzz Box is a bit smoother sounding. You could make the Buzz Box and install a DPDT switch to bypass the first section. Then you'd have both in one box! 8)
~ Charlie
moosapotamus.net
Dragonfly
Quote from: Ge_WhizGGG Op-amp Muff Fuzz:
if you prefer to use vero, theres a verified layout in my folder...
andy
runmikeyrun
yeah i'll second the buzz box.  if you're losing too much bass, use LEDs they clip less but give you more bass through the circuit.
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
