larger verobord sizes in the USA
Started by troubledtom, April 22, 2005, 10:43:40 PM
troubledtom
i don't mind buy'n from aron . but i need some bigger stock.
                thanx,
                     - tom :P
MartyMart
I get mine from "Maplins" ( YUK ! ) in the UK, its like the "Rat Shack" in
the USA........
But its cheap and comes in sheets as big as 8cm X 30cm   !!! which are
about 7 dollars.
So you could make something HUGE with that !  :wink:
Marty.
troubledtom
thanx
 i saw that stuff :wink:
    i wish could get it here.
           peace,
                - tom
PB Wilson
I just bought a larger veroboard at a local electronics store. It's made by a company called Velleman and the one I got is 100X80mm or almost twice the size of the one's Aron sells. It's called "Eurocard Full Line Pattern" and has a single separate pad at each end of the connected line. By the way, the connected lines go the short way, not the long way. They look high quality, are green epoxy board that is 1.6mm thick and are pre-tinned so they won't corrode. It cost me $3.80.
I hope that helps.
troubledtom
troubledtom
nice!!!!!!!!!!!!!! thanx :wink:
    peace,
        - tom
