suggest opamps for LFO's
Started by Brian Marshall, April 30, 2005, 03:06:44 PM
Brian Marshall
In my quest to create a modulation pedal, I have always had one of two problems with with the typical integrator/comparator type LFO's.  I've tried TL072's, which seem to have some linearity problems due to the voltage difference on the power rails.  Power supply noise is also a big prolem.
I've tried Jrc4558/4559's which seem to be more linear, and create less power supply noise, but not quite there.
I have noticed that some older pedals used TL022's.  I have tried them, but they arent quite there either.
It seems to me that an opamp with lower a higher output impedance, and lower power consumption would cure these problems to an extent.  Anyways, I'm going to place  a mouser order this week... anyone have any suggestions?
Gringo
IIRC the small clone uses a lm358 (dual oa) to drive the lfo. Cheap as dirt, too.
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
Joe Kramer
Hi!
I like the TL062 for that type of LFO.  At full output, it does tend to squash one half of the waveform (linearity problems, as you say), but I've found this to be musically enhancing.  It's a low power consumption chip, too.  A TL062 can give a sweep of almost 5V p-p with single-supply circuit--that's pretty decent, and better than I could get with any bipolar op amps.
Make sure you use a big cap (100 uF) on the supply line.  If you get ticking, try a tantalum cap of about 33uF between (and as close as possible to) the power supply pins of the chip.  This has worked for me.
Joe
Solder first, ask questions later.
www.droolbrothers.com
puretube
gez
Brian Marshall
Quote from: gezhttp://diystompboxes.com/sboxforum/viewtopic.php?t=29802&highlight=icl7621
Plenty of suggestions, including my favourite (and RG's now?)  :)
thanks man
Fret Wire
Fret Wire
(Keyser Soze)
