Orange Squeezer +++ PCB
Started by nelson, May 01, 2005, 12:21:12 AM
nelson
Ok updated the layout to have the proper jfet pinout. It should work. I may just etch a PCB myself and scavenge a couple of 2N5457 from an old project.
My project site
Winner of Mar 2009 FX-X
RedHouse
If it wasn't important to have all those pots lined up in a row (which doesn't help anyway) you could fold the circuit in half and the points for that jumper would be very close together.
I can't draw it right now (yes, I'm at work surfing the net) but if you cut the existing pic in half right between the "attack" and gain "pots" and rotate the left piece counter clockwise and repositioned it under the right piece (and redrwaw the traces to conect them) you wouldn't have to have that big jumper.
RedHouse
(OPINION)...
Personally I don't see the need for having the pot pads all-lined-up in a row along one edge of a PCB, it takes up tooo much real estate and cramps the layout.
(I/O and Power also)
Unless one is using PCB mount pots (which is like never 'cause they usually don't fit in 1590B/BB series boxes that way) the pot pads on the PCB should be nearest to the component they hook-up to, sheild as necessary.
(END OPINION)...
This was only an opinion, but it works very well for me and I'm able to get more components into smaller boxes when I dissassociate the pot pads from the edge-connection notion.
RedHouse
Also, I forgot to ask, has anyone built this yet?
nelson
god its only a jumper.    :roll:
I just find it simply more convenient and neater to have the pot pads on the edge.
I am not quite sure what you mean, by moving areas of the PCB.
took me ages to do this, and as I said I havent designed many PCB's.
The layout is compact, I dont think I am going to do any further work on it unless there is a major flaw. Feel free to edit the layout as you wish the PDF isnt protected.
I am currently working on an EH clone theory layout, the MN3007 version.
 :twisted:
After that it will probably be the Echoflanger, I will probably need alot of help on the Echoflanger/polychorus/polyflange. I tried the reissue, doesnt even compare to the originals charm and craziness.
Going to be a fun summer.
My project site
Bernardduur
I build it on a perfboard, and it works like a charm. I love it! My only thing is the quick jump from uncompressed to compressed sound when you turn the bias pot. Tried to adjust is with the trimpot... keeps giving me a compressed sound even with the trimpot turned down complete..... Will try to dissolve the trimpot and use the pot only.
Am learning something new every day here
SquareLight | MySpace account
gaussmarkov
Quote from: nelsonThe layout is compact, I dont think I am going to do any further work on it unless there is a major flaw. Feel free to edit the layout as you wish the PDF isnt protected.
Here's another inexperienced crack at this.  Thanks, Nelson, for the cool puzzle.
I used Cadsoft's Eagle software for this.  At first, I made a version with no jumpers but then I modified it to have a ground jumper at one end and another jumper at the other end.  One could always switch it back to having everything on the bottom layer.
This layout is for either perfboard or pcb.  The pots (VR's) are not meant to be mounted on the board.  Their outline is just part of what's easy in Eagle.  This layout iss on a 10 hole per inch grid.  It's 22 x 15 holes, which is pretty small.  I am the only one who has checked it.
I guess failing to put the pad for the input on the edge is bad form?
ptrx
may i interrupt you for a fairly simple question: i just built an unmodded squeezer (from a tonepad layout) but it's not working and i am currently audio probing the unit (i've done all the measuring and the numbers are quasi right give or take a volt). So here's my question:
is there supposed to be audio at the following points:
after the 470k resistor going to the 100k, diode and 4.70 cap. (the 470k seems to be ok when i measure it, but there's no audio coming out of the other end)
after pins 6 & 7 from the IC (there's audio at pin 5 which i presume is an input to the IC?).
gaussmarkov
hey nelson!  it occurred to me that since you are breadboarding this thing, you could actually figure out the right resistor where the 5k trimm goes.  or not?
nelson
I will measure it with me DMM when I find the sweet spot. I am really busy with exams jus now, I will update this thread when I get round to it, its next on my list :)
My project site
MR COFFEE
Nelson,
You signature line is GREAT!!!
Made me laugh so hard I spit on the monitor.
Damn true too!!!!!!!!!
Bart
ragtime8922
Nelson, nice work. I have a suggestion though. I didn't see many places where you utilized the area under a component for a trace. Remember that you can easily fit 2 traces under a resistor. This saves a ton of space and jumpers. Also, this applys to where you have some U-shaped traces as if they were wrapping around the component but remember that the component is on the other side of the board and that U-shape can be just a straight line.
-Chris
H4T
The jumper doesn't really bother me at all, though I am a n00b, lol. From the looks of this conversation it seems this is a working layout, so I'm gonna try it.
I've been dying to build an OS for a while, but never did because I kept finding new mods for it, and no layouts to match, lol. Thanks for doing this work, I can't wait to try it out!
nelson
I have updated the layout with proper sized IC traces. I had mismeasured originally when drawing.  :oops:
If you plan on building this please use the most up to date layout.
can be found here.
http://www.auaj24.dsl.pipex.com/os+++V2.pdf
This means you H4T
Enjoy.
My project site
RedHouse
pakalolo
Shouldn't R5 (470 k) be connected to R6 and C5 ?
nelson
Your right....Thanks.
Layout changed.
Use same link. :)
My project site
mojotron
Has this layout been verified?  :D
nelson
Still havent built it yet....A compressor isnt high on my list of builds.......
Sorry, I will get round to doing it eventually.
My project site
mojotron
Quote from: nelsonStill havent built it yet....A compressor isnt high on my list of builds.......
Thanks for the note, I'm building one today, I'll post notes...
Also, thanks for the layout, if I make changes to your layout, can I post the changes as a .gif file on this forum?
