[TUBE] AGC / Limiter provides constant output amplitude
Started by puretube, May 03, 2005, 05:51:27 AM
puretube
without opto-components ( :!: ):
http://v3.espacenet.com/origdoc?CY=gb&LG=en&F=4&IDX=US2534111&DB=EPODOC&QPN=US2534111
can be modded by those skilled in the art a little for "sound"-purposes
(this principle can easily be adapted by more uptodate electrical amplifying devices... :wink: )
Johan
...I blame it on having been a long day...but I dont see it..cant decifer it.. :cry:
..but since you're here, talking about tubecompressors...I'm about to take my first stumbeling steps into designing and building a supersimple vari-mu compressor..but these are new to me..do you know anything about how they work...and if so, if I draw up a first sketsh and mail to you, could you tell me if I'm on the right track?..
thanks..
johan
DON'T PANIC
puretube
sorry: "vari-mu" is too close to some current developments - so I don`t wanna talk about it... :cry:
Johan
..no problem...good luck with yours, and wish me luck with mine.. :D
...I am mostly after seeing if I got the principles down and how simple I can make it and still have it sounding decent..I never liked electronics that looks like the designer got payd buy how many components he used...simple circuits is my thing..
johan
DON'T PANIC
puretube
simple:
http://l2.espacenet.com/espacenet/bnsviewer?CY=de&LG=en&DB=EPD&PN=US2414475&ID=US+++2414475A1+I+
(this is a spin-off of today`s phase-sh*ft stuff - replace C1 with a resistor (maybe de-coupled/blocked by a large cap,
and you`re almost there... for CV: try anything you like)
cd
Quote from: Johan...I blame it on having been a long day...but I dont see it..cant decifer it.. :cry:
Well mu means gain, right, so how do you vary the gain of a tube stage?  These two links may inspire you:
http://www.manleylabs.com/containerpages/mu99.html
http://www.primalgear.com/gygvamuco.html
On another note, think of the bias modulated tremolo in old Fender amps.  What if the bias was not modulated by an LFO, but by a sidechain?
Johan
Quote from: cd
well..as I undersstand it..you can vary the mu of a tubestage by variyng the biasvoltage ( in simplified terms.. ). so, if Im correct it wouldnt need much more than a sidechain supplying a negative voltage mixed with the signal into the grid of a tube...as I said, I want to make it supersimple, so the end result might not be that great...but I'm only doing it to see if i got the fundamentals right...
Johan
DON'T PANIC
moosapotamus
moosapotamus.net
Johan
Quote from: moosapotamusI may not know mu from moo, but here's another good reference...
http://music-club.rutgers.edu/headfonz/comp5/Comp5.html
~ Charlie
..thank's "moose"...I've seen that one..but you know me..I always have to do thing my own way and if I can cut parts and simplify in any way, I will...and transformers and caps ( unless for filters..) are my enemies..there simply have to be another way.. :twisted:  ..I think I have it figured out..it'll be a while before I can test it..but think "cathodefollowers and voltagedoublers"...
Johan
DON'T PANIC
moosapotamus
Yeah... Cool, Johan! I'll be interested to see (and maybe hear) what you come up with.
I actually kinda like transformers, tho. I have an awesome little phantom powered DI box (Bo Hansen's design) that I built using a Lundhall traffo. 8)
Best!
~ Charlie
moosapotamus.net
