OT: buying an oscilloscope
Started by ethrbunny, May 05, 2005, 07:21:30 PM
ethrbunny
Im looking at o-scopes on ebay. Each has a 'bandwidth' listed at the bottom.  What sorts of frequencies are we dealing with in stompboxes? All I can think of are vibrational frequencies (IE 'a' = 440 hz).
Also - are there models to steer to / away from? Or a better source here in the NW US for a used 'scope? Boeing surplus?
--- Dharma Desired
"Life on the steep part of the learning curve"
toneman
almost any scope will work for audio.
Say, 1MHz bandwidth.
Make *sure* it's a --TriggeredSweep-- scope.
Most new/recent//solid-state ones are.
they will have a "trig" knob with + and -.
This means it can trigger on the positive-going transition,
or the negative-going transition.Most will have "auto trigger" also.
Lots of scopes on ebay. Lots of good deals; lots of junk.
Try to get a dual trace scope.
Much more usefull for comparing ins & outs simutaniously.
One last thing, look for probes while you're at it.
There are generic probe sets, AWA the ones that originally came with some scopes.
My 465B, that's a Tektronix, came with 2 Tek probes.
I've seen just the probes for $20 to $40 each.
I use a scope for nearly everything--voltage, waveforms, frequency, timing.......
stayscoped
tone
niftydog
Tektronix, Fluke/Philips and Agilent are great brands - although you're not likely to encounter them cheaply, except maybe an old tektronix.
Ensure the CRT still works, because they are nigh on impossible (or stupidly expensive) to replace.
oh, and audio range is considered to be 20hz to 20khz at absolute maximum. Just about any scope will suffice for these frequencies.
niftydog
Shrimp down the pants!!!
ethrbunny
Great stuff. TY.
Quote20hz to 20khz at absolute maximum
QuoteSay, 1MHz bandwidth.
How would I know whether a specific model satisfied these needs?
The models on ebay are generally listed like:
foo model 28 - 100 mHz
or
quack model a1a - 35 mHz
Is the frequency # the maximum sweep rate?
--- Dharma Desired
niftydog
the frequency is the bandwidth of the scope inputs.
1M or higher would be fine for audio stuff.
niftydog
ethrbunny
Quote from: niftydogthe frequency is the bandwidth of the scope inputs.
So if I got one that said, say 100mhz it would still work for the slower stuff?
--- Dharma Desired
brett
Hi.  Yeah, the bandwidth over 20kHz in scopes isn't necessary for boxes *unless* you have some high frequency signal in a clock or oscillator or similar to monitor.
Don't forget the hand-held scopes such as the Velleman HPS5 and HPS10.  They not only display the waveform, they calculate peak to peak and RMS voltage, estimate frequencies (though I think it's only to nearest 0.5kHz, which is annoying for audio work).  They are solid-state and fairly cheap.
Whatever you get, you'll find a scope very handy.
Brett Robinson
niftydog
QuoteSo if I got one that said, say 100mhz it would still work for the slower stuff?
absolutely.
niftydog
ethrbunny
Would this one work?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=104247&item=7510298852&rd=1&ssPageName=WDVW
I might have a local offer for US50$  to get one.
Unf - I can't find any more specs on it. No clue whether it has 'auto triggering' or not. I haven't used an oscope since I was in high school.. and *that* was a while ago. Yikes!
--- Dharma Desired
niftydog
it looks good. it does auto-trigger.
The add is slightly vague, which would turn me off. And the sentance "The unit does not include the power supply but appears to be in perfect working order" is slightly scary...
power supply? Maybe he means the cable. "appears" to work... hmmm.
That seller isn't doing himself any favours by posting such vague drivel on the add.
niftydog
ExpAnonColin
I would definitely get a scope that could go over the audio range (.1hz to maybe 10mhz) so you could measure everything from slow LFOs to clock signals.
-Colin
niftydog
What Colin says is right, but just to clarity - you don't have to worry about the lower end of the bandwidth. All oscilloscopes measure right down to DC (ie; 0hz).
And it's pretty rare these days to see a scope with less than 10Mhz bandwidth.
niftydog
ethrbunny
Awesome. Thanks for all the speedy responses.
--- Dharma Desired
H.Manback
Well this is a coincidence. I actually worked with this one (I think) at school! We used the new tektronix scopes which are completely digital, but I wanted to see what the difference would be with one of those old fashioned scopes.
Of course this is no comparison since those tektronix things go for like around $1000, but I did prefer the new ones ;). I didn't spend much time on the thing, and I couldn't figure out how it works that fast (I do computer science, and I just followed this one electronics course at the physics department, so that was the first time I even used a scope).
The specs seem pretty good as said by the rest here, 35MHz is more than enough, and it looks like some probes are included as well.
troubledtom
by the way this NOT OT  :P , a scope is very cool to have and learn how to use.
  best wishes,
         and be careful on e[evil]bay :wink:
                    - tom
ethrbunny
(bump)
Im going  to look at an hitachi scope sometime this weekend. What sorts of tests should I do / things to look at before I buy?
--- Dharma Desired
toneman
Hey EB,
First U will need a probe
So U can check the input amplifiers.
Sometimes, but not always,
there is a test/calibration squarewave signal
on the front of the scope.
Hang your probe there, check the proper scale/resolution.
That way U can check triggering, amplitude accuracy, etc.
Hitachi makes good little scopes.
HOpe it's a dual-trace....
good luck.
tone
barret77
are those software-oscilloscope for windows any good?
toneman
software-based Oscopes R not DC coupled.
that is, they only read AC signals.
Might B OK 4 U if U just want 2 view stompbox waveforms.
But, if U *really*really* want 2 troubleshoot,
a good scope can measure DC, AC, frequency, period, &
heh, those waveforms look far-out man.  tone
