Size of wire in inductor coils
Started by shawsofhell, May 12, 2005, 04:16:55 AM
shawsofhell
I am winding my own wah inductor and am using this assembly http://www.altronics.com.au/index.asp?area=item&id=L5300      My question is what is a good sized wire to use. (The smallest diameter I can find is .125mm)
niftydog
it depends on the inductance you require, how many turns you wish to use and the current you expect it to handle.
I guess thin wire gives you more options to wind more turns on to the former.
niftydog
Shrimp down the pants!!!
littlegreiger
I'd recommend getting the stuff from Smallbear to make your own wah inductor. He has a Halo inductor kit and winding wire. His wire is #38.
shawsofhell
this wire is 36awg where as the small bear stuff is 38awg. Is this going to make a big difference to the sound?
niftydog
only if you're into extreme mojo.  :D
niftydog
Paul Perry (Frostwave)
Normally, one uses the thickest wire one can, so that the series resistance (and hence losses) is as low as possible.
But in this application, I don't personally think it will matter.
