RAT 2 PROBLEM....I TOOK READINGS. CAN SOMEONE INTEPRET?!
Started by dannydowrong, May 13, 2005, 07:10:31 PM
dannydowrong
i tried following aron's suggestions as best i could. the unit will not sound up, although if i crank the level pot, i can hear VERY slightly the signal. when i short the drive and level pots' solder joints, i get a full functioning signal with the switch working too. anyway..any help greatly appreciated.
RAT 2 (cream circuit board). red LED, LM308 chip.... no sound when engaged, sound when i short (touch one with each hand) outter solder joints of two outer pots. switch works when i short these.
readings when unit turned on (red LED with 1/4 cord into input)
battery voltage    7.21 (in circuit)  7.25 (disconnected)
IC pin readings:
1)6.35
2)3.5
3)1.09
4)0
5)5
6)3.5
7)7.05
8)3.56
transistor A   Base=7.02   Collecter=2.82      Emitter=0
transistor B       =7.03            =6.58             =.63(LED flickered when tested)
one leg of the 6 legged switch read .62, the rest read zero
either lug on power jack=7.15
all 3 level pot solder joints               3.48
all 3 drive pot solder joints               0.00
all 3 filter pot solder joints                0.00
help please :lol:
hold on folks
We really need a bit more info. See the sticky "What to do when it doesn't work" at the top of the forum and see if you can supply:
link to the schematic
voltages with a non-dying battery (over 8.5V)
