what trany's for mosrite fuzzrite?
Started by add69, May 15, 2005, 09:15:27 PM
add69
this looks like it a easy circuit. I used to have one man was that some nasty fuzz!! so dose any one know what trany to use in this circuit I have an RCA replacement guide but can't find it. so any help would be cool thanks in advance Guy's
nightingale
Check out  the archives,
I can remember several threads discussing how different trannys sound in this circuit.
hope this helps,
be well,
ryanS
www.moccasinmusic.com
The Shin-Ei FY-2 is very similar to the Fuzzrite.  Though I have no idea how similar the sound is/was, the FY-2 is also very nasty sounding and might be able to serve your jones.  It used 2SC536 transistors, which are still quite available.  Try em out and see if you like em.
col
I had the best results with BC184Cs, BC108s had a strange decay and most others I tried introduced squeal. BC107s sounded great but had less than unity gain. The BC184Cs sounded great and had smooth decay, the sustain on this circuit is incredible!
Col
