Veroboard layout for Java boost
Started by pnak, May 30, 2005, 02:10:57 PM
pnak
I Am looking to build a java boost and found out that there
use to be a veroboard layout that was available. Does anyone
have it and wouldnt mind sharing it with me I would
appreciate it very much.
gotdabluz
that was one of Torchy's now evaporated layouts . . . I happen to have a copy on my hard drive
pm me with your e-mail addresss, and I will send it to you . . . I promise not to put you on a spam list  :)
--SG
pnak
THe pm thing doesnt seem to be working.
barret77
hi
If any good soul would not mind sharing a vero layout for java boost with me, I will be really really grateful.
The PM is having problems, my email is carloslunetta77 at yahoo dot com.
really thanks!
barret77
great! thanks a lot to everyone!
And thanks to keeley and torchy as well!
xshredx
Quote from: barret77
Yes!!
And please torchy: come back!
kashmir
How do you have to adjust the trimpots and what is the the function of the SPDT switch? Thanks for the lay-out btw!
hairyandy
I adjust the trimpots to taste, although theoretically there is a "correct" voltage that a given transistor should bias at.  Read R.G.'s PDF on the Rangemaster at GEOFEX.  You'll know when it's biased right because it'll sound great.  When the bias is wrong it doesn't sound so good.
The SPDT switch just switches between different input caps to change the tone.  The Keeley Java Boost has a three -way switch that is treble-mid-bass emphasis.
Andy Harrison
It's all about signal flow...
Hairyandy's Layout Gallery
kashmir
Ok, I'll read the article. Thanks for the info Andy.
bean
Quick question: I have finished this build, and it seems to work fine except for my tone control which has little or no effect. Sorry for the n00bness of this, but do I need to connect lug 2 to 1 of the tone pot? The vero layout doesn't indicate this.
dansamp
the tone pot does not do very much
in mine it seems to work more like a very mild cut control
i had the chance to compare it to a real java boost
and the real one has a much more affective tone control
the sound on my clone is just as good though
mine seemed more raw and in your face
the real one seemed more refined and to me more conventional
dan...........
bean
I got it all worked out. Replaced the 10nf @ C7 with 100nf and that gave me the tone variation I wanted. Little too much drive by itself on the volume side, though, which I can't really dial out with the trim pots. Sounds really nice in front of other OD pedals.
