dual ruby layout
Started by PurpleTheory, June 04, 2005, 03:38:14 PM
PurpleTheory
hey guys, here is a layout i made for a dual ruby (based on ROG's ruby), the one i built seems to work fine, please let me know if you have any suggestions to make it better.
http://home.comcast.net/~knowitallrocks/temp_images/dual_ruby1.pdf
cheers,
matt
birt
i just made one using my own lay-out :lol:
http://www.last.fm/user/birt/
PurpleTheory
is yours set up about the same? did you use any different parts or anything?
birt
i don't use a voltage regulator.
my lay-out is built around one 16pin IC socket and so it's quite different from yours.
i'm still trying to mod stuff to get other sounds and i use 2 2n5457 jfets in parallel
MetalUpYerEye
is this a bridged ruby that will deliver twice the power of the original ruby?
