maestro fuzztone (the satisfaction one)
Started by doug deeper, June 11, 2005, 08:20:37 PM
doug deeper
is there a scheme floating around for this???(cant seem to find one)
also has anyone built one?
opinions?
d.
There are schems around for all of the Maestro fuzzes. Picking out which one was used on Satisfaction is the problem.
gez
brian wenz
Hello Hello-
     I built a few FZ-1A  Maestros using Gez's notes on biasing and they all sounded GREAT.......Much better then alot of "stock" units I've heard.  A really cool fuzz to have!  I used 2SB Japanese  germanium trannys  [pretty close to the original tranny] and I don't think  any other trannys would sound quite the same.  [ Others will work fine, though.]
Brian.
gez
Quote from: brian wenzI built a few FZ-1A  Maestros using Gez's notes on biasing and they all sounded GREAT.......Much better then alot of "stock" units I've heard
Thanks for the feedback Brian, glad to know I didn't imagine it all!  :)
brian wenz
Hello Hello--
   Hi Gez!!
 Yeah, I kept a copy of your notes with my  Maestro / Shin Ei schematics.
What trannys did you use for your FZ-1A ??.
B.
gez
Brian, I scored a mixed bag of Ge trannies from a local Radio repair place.  They were all NKT types, 212-7325 and I think 214-7312.  I also tried some AC126 and they sounded fine, though the NKTs had better gain figures on the whole.
brian wenz
Hello Gez--
   Did you find that the type of tranny didn't matter too much??
B.
gez
Quote from: brian wenzHello Gez--
B.
There was no difference between any of the devices I used Brian.  I built three, all with different combinations of trannies (and I tested loads!), and they all sounded exactly the same.
That's not to say all Ge's will sound great in there though (one type I had sounded duff), but so long as you get the bias right it doesn't seem to make much difference.
col
I built one of these on stripboard and couln't get it to work. Then I noticed that the schematic said 1.5v! Is this correct? I need to get back on with this one but havel eft it for a few weeks. I used some 'red spot germaniums' which were tested for function but not gain. I also tried a few other Ge pnp trannies but still got no output with 9v.
Col
Col
gez
The 1a runs from a 1.5V supply, not 9V.  If you want to add a LED too, the Battery friendly way of doing this is as follows:
Adjust wiper from ground (+9V) till you measure 1.5V at the MOSFET's source.
It's crude, but it works...
brian wenz
Hello Hello--
   Thanks Gez.
 Not only is this circuit a good fuzz, but when played through an overdriven amp it can be a great overdrive / distortion.....nice and thick!
Brian.
