request: dd-6 hicut mod
Started by spacedog, June 21, 2005, 12:36:28 PM
spacedog
hi
i´m looking for the dd-6 hicut mod. maybe anyone can post a (more or less) detailed description on how to perform this.
all i found on this topic is this
QuotePostPosted: Fri Jan 28, 2005 3:49 am    Post subject: dd-5 mods
by donald stringer
I have been waiting for some info. on this pedal. I have had it apart for two weeks. You can do the hi-cut mod on the dd-5 on the back of the blend control. I thought 1uf was a little dark though,a .22 suited me but to have a choice in the matter and not have to drill any hole in the pedal I soldered the wires onto the back of the blend control and ran them out the output jack [file a tiny notch to accomadate the wires and I will mout an external switch to choose between the two. It works just fine.
i´m sorry but i don´t really understand where to solder the wires exactly. maybe someone can give me a hint.
thanks!
.gert
wampcat1
Hi Spacedog - unfortunately it doesn't work on the dd6 -- I've tried both the effect level and the feedback pot. I do recall seeing someone post the basics of it -- I believe it was Mark Hammer. You might pm him to see, or look up his previous posts with the search phrase "dd-6"
AnalogMike has one, he may tell you the how-to. It's on my (ever growing) to do list, when I get around to it, I'll post it here.
Hope that helps! :)
Thanks,
Brian
7XL
I, too, am looking for info on performing this mod myself. I could probably figure it out if I could find a schematic for a DD-6. I did read on some other site that it involves a resistor and not a capacitor as in the DD-3/DD-5 mod. If I fnd any more info on this, I'll be sure to keep you updated.
tmuka
Quote from: wampcat1 on June 21, 2005, 05:29:44 PM
I tried putting caps on the level and feedback pots too with no success...
