one bass into two amps
Started by me, June 21, 2005, 09:05:34 PM
me
new to post, yes.  But I have looked over and over for a A and B, not A or B.  It could be as simple as A and B all the time (but either or would be a good touch).  I have looked and looked but  can only find A or B.  Anyone bored enogh to help.  Thanks
niftydog
a simple op amp buffer circuit should do the trick. Maybe try searching for the correct terms, rather and "A and B" or whatever... like maybe "op amp splitter" or something.
niftydog
Shrimp down the pants!!!
nelson
you want an active A/B/Y dont you?
isnt there one over at GGG + GEO?
http://www.generalguitargadgets.com/index.php?option=content&task=view&id=71&Itemid=102
I plan on building one too..........
This is designed to avoid the various problems associated with running two amps....
My project site
Winner of Mar 2009 FX-X
sean k
There is one at geofex,R.G.Keens site,which is the updated schematic and features an A or B and a A and B switching pattern.I'm building one with A or B and MIX with a booster in front and a momentary tuner out.Do you want the schematic for that?
Monkey see, monkey do.
Http://artyone.bolgtown.co.nz/
me
Thanks dguys this will help.
