Bad Resistor?
Started by Bill Bergman, June 24, 2005, 09:06:08 AM
Bill Bergman
Can a resistotr be bad and still give the right value reading on a DMM?
I noticed a slight off-color ring around a certain resistor that's not a regular color band in a circuit that's not working.
niftydog
potentially. (ha ha ha... ha... ahhh forget it.)  :?
Well, I suppose it's possible, but maybe more prevelent in high voltage or highly sensitive circuits.
To properly check a resistor it must be removed from the circuit.
discolouration can be a sign of excessive heat, but resistors are pretty hardy beasts.
niftydog
Shrimp down the pants!!!
Bill Bergman
Thanks.
Yeah it was overheating but hadn't burned out.....yet.
Eric H
Quote from: Bill BergmanThanks.
Bill, unless that overheating was a construction error --never to be repeated ;) you might want to replace it with a larger wattage-rated one (like a 1watt instead of 1/2 watt)
" I've had it with cheap cables..."
--DougH
Bill Bergman
Thanks Eric!
It is due to an error. I've got 150vdc coming of of the grid pin of a power tube. It's supposed to be 0vdc. :?
