rangemaster clone...gain works backwards?
Started by emerswin, June 25, 2005, 01:57:49 PM
emerswin
Hi,
I've built two for the rangemaster clones from the GGG website. http://generalguitargadgets.com/diagrams/geb_rm_lo_pn.gif They work fine except the gain control work backwards on both units, as in more gain is counter clockwise. I followed the layout in the link exactly, except have added in a on/on toggle switch to choose between two different input caps. I can't imagine that would have any effect on the gain pots function? Any thoughts on where I've gone wrong? I emailed the GGG website to see if he has possibly drawn the layout wrong, but haven't heard back just yet....
Fp-www.Tonepad.com
You have a backwards pot.
All you need to do is reverse pins 1 and 3.
Fp
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
aron
Reverse the two outer lugs of the gain pot.
aron
That is the back of the pot. Is that the way you wired it up?
Fp-www.Tonepad.com
Actually it DOES seem like the layout is wrong.
Pin 1 should be ground.
Fp
aron
Fp-www.Tonepad.com
hehe.. funny how we both replied within seconds.
Fp
emerswin
Thanks....so the layout is wrong, for sure? And I should reverse 1 and 3? Just double checking before I fire up the iron...
Fp-www.Tonepad.com
What does the pot look like when you say pin 1 ?
 I could never follow...so for ease of description...in the case of a volume control pot, which pin connects to ground?
 I'd like to know for wiring tone controls properly.
 For volume controls, I just turn the volume shaft CCW stop, imagining I have a knob on there pointing to the 'off' lug, and connect that to ground.
phillip
Quote from: petemooreWhat does the pot look like when you say pin 1 ?
If you're looking inside the pedal (at the backs of the pots), with the solder lugs pointed down, lug 3 is the one on the far left.  Lug 2 is the wiper (center lug), and lug 1 is the one on the far right.
Phillip
Fp-www.Tonepad.com
What he said :)
I always thought it had to be the other way around, but it becomes logical after a while.
I was 'just kinda figgerin' it' and would get most of the pots wired 'straight' except the tone pots...it would be 50/50 chances whether I'd have to swap outside lugs...lol.
 Thanks, that clears it up !!!
Fp-www.Tonepad.com
it is common to draw the layout with the pots as you would see them from inside the enclosure.
I have updated some of the pdfs to show a more detailed drawing of the pot.
Fp
