My amp is limiting.
Started by moeburn, June 29, 2005, 02:37:51 PM
moeburn
I noticed that when I tried playing my tube screamer on certain settings, i wouldn't get any sound out of my amp.  However, if I turned the amp's volume way down, it would sound beautiful, like it was supposed to sound.
Somewhere halfway in between that volume setting, my amp is sort of "limiting" the sound.  If i play quietly, the amp plays it fine, but if I play harshly, the amp cuts out and plays nothing at all.
What can I do to my amp to fix this?
cd
Sounds like blocking distortion.  Turn down the level of the TS.
moeburn
Quote from: cdSounds like blocking distortion.  Turn down the level of the TS.
Problem is, my TS is also going through a homemade LM386 booster without a volume control, so turning down the TS doesn't help much.
guitarhacknoise
Quote from: moeburn
Problem is, my TS is also going through a homemade LM386 booster without a volume control,......
Taa Daa!
or Rather, Taa Daa?
-matthias
"It'll never work."
cd
Quote from: moeburn
Well there's your other problem right there.  Get rid of the booster.  The LM386 is a POWER amplifier designed to drive speakers.  If you want clean gain it's not supposed to be used to drive a line level input.
You're using a solid state amp, right?
