ce-2 chorus vibrato bypass mod not 100%...
Started by hershey, July 02, 2005, 04:28:38 AM
hershey
Hi all,
I did ce-2 vibrato mod as per topic here:
http://diystompboxes.com/sboxforum/viewtopic.php?t=31668&highlight=ce2+vibrato
and diagram here:
http://home.earthlink.net/~ehansen3/diy/ch1vibratomodschem.gif
I used a 2sk118.  the bypass works fine in vibrato mode, however I don't get vibrato effect, just the same chorus effect as when it is switched off (chorus mode).
When I remove the 2sk118, I get the vibrato effect but no bypass in vibrato mode (obviously).
Question I have do I wire the FET and wires to each ends of the spst switch? B/c I wired it to one end and the middle lug of the spst switch
ANy help is appreciated. Thanks!!
hershey
ok I realised I soldered wires in wrong place. 47k r21 remains intact on board, but remove the jumper b/w r21 and pin2 of ic2 and solder wires there.
Wired up dpdt method, o.k bypass in both but switching b/w chorus and vibrato there is no change in effect, just stays in chorus mode.
any pointers??
vanhansen
Oh man, I thought I removed that schematic.  The one you linked to is for the CH-1.
The one you want to look at is here:  http://www.erikhansen.net/diy/ce2.htm
This page has the steps outlined for doing this mod with wiring diagram.
Good luck.
Erik
jimbob
that was cool! has anyone tried these yet?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
vanhansen
Quote from: jimbobthat was cool! has anyone tried these yet?
I have a CH-1, not a CE-2, but I've done the delay range and ring modulator mod to it and it sounds great now.  The delay range mod I highly recommend if you want to thicken up the sound by increasing the value of C10 (CH-1) or C22 (CE-2).
Erik
jimbob
I have a ch1- what are the mods for it?
vanhansen
Quote from: jimbobI have a ch1- what are the mods for it?
Go to my site.  Under the Mods/Info section there's a page for the CH-1.
The Chorus/Vibrato mod isn't worth doing.  You'll read about why in that section.
Erik
hershey
Sorry posted wrong link.:oops:
I believe one guy has done it.
I've done it but to me it doesn't work. wiring it you don't get the vibrato effect when you switch back and forth, you just get chorus effect.
